This sound effect has four individual loop roll effects in one package. I havent been able to assign them individually to a button. I can only assign the plugin as a whole , not able to key in on individual loop roll effect. Anybody?
geposted Sun 05 Sep 10 @ 12:02 pm
Heres the link to the thread,
http://www.virtualdj.com/forums/131515/Hardware_Technical_Support/Novation_Dicer_midi_cont%3Cspan%20style=, but for time seeks I'll type the script out if your just using a keyboard, lol!
Button 1 "effect "SMX1_XF-FX" active while_pressed & effect slider 1 85%"
Button 2 "effect "SMX1_XF-FX" active while_pressed & effect slider 1 75%"
Button 3 "effect "SMX1_XF-FX" active while_pressed & effect slider 1 65%"
Button 4 "effect "SMX1_XF-FX" active while_pressed & effect slider 1 35%"
Button 5 "effect "SMX1_XF-FX" active while_pressed & effect slider 1 10%"
But to get it to sound like what was in the video you would have to 1: map a button to turn the effect on 2: map a fader for the slider and boom it should work................havent tried it myself but in theroy it should work, lol!!
Huey
Huey
geposted Sun 05 Sep 10 @ 12:06 pm
Thanx for the quick reply. Im actually using a combination of keyboard, to select the effect, and then my Numark NSFX controller. I would like to be able to trigger each individual roll effect and then manipulate each one with my NSFX controller. Thanx in advance beatbreaker1.
geposted Sun 05 Sep 10 @ 8:01 pm
