I just installed Virtual DJ and for some reason if I try to scratch it doesn't play any sound as I move the record backwards. It works fine if my scratch the record forwards. Does anybody understand what I mean and know how to fix it?
geposted Sun 19 Sep 10 @ 2:19 pm
You have "Smart Scratch" turned on. You must have activated the shortcut. Turn it off and youll be good.
Huey
Huey
geposted Sun 19 Sep 10 @ 2:22 pm
Hello
I had my numark mixtrack for a while but now it wont scratch forward or back , sometimes the closest i get to a scratch is the pitch going faster or slower when i move the jog wheels on scratch mode. Also sometimes when i touch the jog wheel the music will stop and not continue unless im touching the jog wheel. idk what to do D:
geposted Tue 21 Jan 14 @ 5:16 pm
For the issue nr 1:
Make sure that your jogs are in "Vinyl" mode and not in CD (Jog) mode
For the issue nr 2:
Make sure that you don't have any custom mappers loaded. Go to "Documents\VirtualDj\Mappers" keep a backup of the files in there (if any) and delete them all.
For the issue nr 2:
geposted Wed 22 Jan 14 @ 1:20 am
