Hi VDJ community!
So, I have the scs3 system, and before now I have been using Traktor for mixing. I have decided to give VDJ a try but there is one more problem I need to figure out before I consider buying the full version.
As the scs3 system is a touch pad, the way that the pitch slider works (absolute) is not useful if you want any sort of precise control over the pitch. Even if I set the levels to as low as they can go (+/- 6%) it's still almost impossible to get a precise pitch level because of how sensitive the touch pad is.
I have seen talk of VDJ needing a relative mode for the pitch but I have yet to find a solution and I am having trouble mapping one myself. The mapping shows a pitch_relative, but I can't get this to do what I want (or if it is even what I'm looking for).
What I want to be able to do is, like in Traktor, to have the slider, instead of setting the pitch based on where I slide my finder, I want it to gradually increase or decrease the pitch when i slide my finger up or down the slider.
If anyone could show me the setting for doing this or EXACTLY to map this function, that would be GREAT. I have tried to map B12 as a shift (as I don't require the key lock originally assigned to it) and then have the pitch slider (S2) change to a relative mode whenever the shift is toggled (not have to hold down shift).
Any help would be greatly appreciated!
Thanks!
Thanks!
geposted Tue 21 Sep 10 @ 2:07 pm
Hi, I'm having the same problem with my SCS.3d.
Does anyone have any idea how to configure the pitch slider from absolute to relative?
Thanks!
Thanks!
geposted Sun 11 May 14 @ 2:42 am
