Forum: VirtualDJ Skins
Topic: Vumeter x 2 in version 6.x
Hi,
I am trying to convert MixLab 3.1 with some added features to VDJ script 6 but have got stuck.
I am using VDJ 6.12 pro.
I am trying to get a pair of horizontal vu meters on one deck:
<visual pannel="51" source="deck 1 get vumeterleft" type="linear" deck="1" orientation="horizontal" direction="right">
<size width="353" height="11"/>
<pos x="84" y="47"/>
<up x="78" y="1237"/>
<down x="175" y="2066"/>
</visual>
<visual pannel="51" source="deck 1 get vumeterright" type="linear" deck="1" orientation="horizontal" direction="right">
<pos x="84" y="67"/>
</visual>
But only the top one works and I can't understand why?
I have tried changing the bottom one to vumeterleft and that doesn't work either.
Is there a limit on the number of VU meters in vdj 6.12??
Also
can someone explain the diffrences between vumeter and vurmeterleft and vumeterright
also
get level_left and get_level_right
It's a steep learning curve, but I am determined to get to grips with the VDJ Script.
Thank you.
geposted Thu 23 Sep 10 @ 5:52 pm
use "deck 1 get level_left" and "deck 1 get level_right"
get level_left/right will produce stereo readings - vumeter in mono.
geposted Thu 23 Sep 10 @ 6:32 pm
perfect thank you for your guidance
Can I ask a further question of you
The bargraph vu meter does not work
<visual pannel="50" source="deck 1 get vumeterleft" factor="1.5" type="linear" deck="1" orientation="vertical" direction="up">
<size width="13" height="25"/>
<pos x="79" y="50"/>
<up x="615" y="2680"/>
<down x="993" y="2680"/>
</visual>
These are stepped across with different factors to give the appearance of a bargraph vu meter
Sorry to ask so many questions, but I am learning a heck of a lot about VDJ Script 6
Just confused about the different verbs regarding levels etc.
Thanks
geposted Fri 24 Sep 10 @ 3:27 am
As far as i know the "factor" part doesn't work anymore. Hasn't worked since V6 was released. As far as i am aware!
geposted Fri 24 Sep 10 @ 3:47 am
Ah that would explain it.
I can get the levels to appear but like you siad it ignores the factors - damn!
All I can do for now is alternate the sources from left channel and the right chanel to give some sort of effect.
Better than nothing.
Do you know if this to be fixed in the next release?
Thanks
geposted Fri 24 Sep 10 @ 4:22 am
No i'm not sure. Your the first person to mention as far as i'm aware. Just have to wait and see i suppose.
geposted Fri 24 Sep 10 @ 5:17 am
Hi,
Is there anything esle that doesn't work in VDJ script 6 that I should be aware of.
What about Custom?
this is in 6 and doesn't work
<visual pannel="52" source="deck 1 get grid" type="custom" deck="1">
<size width="119" height="25"/>
<pos x="81" y="50"/>
<down x="1032" y="3326" nb="5" nbx="1"/>
</visual>
In 5 - it worked
<visual pannel="52" type="custom" source="grid" chan="1">
<pos x="81" y="50"></pos>
<size width="119" height="25"></size>
<down x="1032" y="3326" nb="5" nbx="1"></down>
</visual>
Am I off on another wild goose chase? lol
Mark
geposted Fri 24 Sep 10 @ 7:07 am
get grid doesn't exist in V6 either.
What did it do in V5 - there maybe a new verb/syntax for it.
geposted Fri 24 Sep 10 @ 7:24 am
You're missing a Y in this line...
<down x="1032" y="3326" nby="5" nbx="1"></down>
BTW: Custom works fine... I always use custom on my vu-meters (so that each "led" light's up as it would do on a hardware mixer)
geposted Fri 24 Sep 10 @ 7:33 am
I'm slowly loosing the will to live here!
the wiki states:
<up x="" y="" nb="" nbx=""> : (type="custom" only) Give the coordinate of the graphics to use with the custom type (works like for a "round" slider)
and not
<up x="" y="" nby="" nbx=""> : (type="custom" only) Give the coordinate of the graphics to use with the custom type (works like for a "round" slider)
Crikey please get the documentation correct!
Thanks guys
You have been most helpful
geposted Fri 24 Sep 10 @ 8:35 am
Adding a nby= errors
<visual pannel="52" type="custom" source="deck 1 get grid" deck="1">
</visual>
whereas:
</visual>
does not, but does not work
I'm confused - Im going to put this one down for a while and come back tomit when I have the patience!
geposted Fri 24 Sep 10 @ 8:52 am
As i said before "get grid" is not a V6 action. What did it do it V5 as there may be a new action in V6 that does the same thing.
geposted Fri 24 Sep 10 @ 11:19 am
Hi,
in 5 get grid allowed the use of graphics say to represent the beat.
BTW
nby="5" is not a valid syntax.
geposted Sun 26 Sep 10 @ 10:56 am
Try one of these - "get_beat" or "get_beatgrid"
Maybe one of those will do what you want - not used them myself so can't say for sure.
geposted Sun 26 Sep 10 @ 11:30 am
JeremKPRO InfinityModeratorMember since 2004
Hi Mark,
In v6, the get grid is replaced by "goto_bar x" where x is 1, 2, 3 or 4
You can even use it as a button in v6.
Replace "<visual>...</visual>" code by the following, it should work:
<button action="deck 1 goto_bar 1">
<size width="24" height="25"/>
<down x="1032" y="3326"/>
</button>
<button action="deck 1 goto_bar 2">
<pos x="105" y="50"/>
<down x="1032" y="3351"/>
</button>
<button action="deck 1 goto_bar 3">
<pos x="129" y="50"/>
<down x="1032" y="3376"/>
</button>
<button action="deck 1 goto_bar 4">
<pos x="153" y="50"/>
<down x="1032" y="3401"/>
</button>
geposted Sun 26 Sep 10 @ 2:01 pm
Thank you for your reply.
I'm not 100% sure about what you are saying - but I will look at and see how that fits.
I guess for me it's a steep learning exercise - and I am finding that version 5 scirpt on the face of it seems more flexible.
An example of this iis the samples.
I have a slider to change the volume of say samples 1
<slider pannel="72" action= "sample_volume_1" orientation="vertical" dblclick="reset" rightclick="temporary">
<size width="11" height="89"></size>
<pos x="532" y="269"></pos>
<up x="1037" y="2765"></up>
<selected x="799" y="3693"></selected>
<fader sensibility="100">
<size width="11" height="16"></size>
<pos x="947" y="1857"></pos>
</fader>
</slider>
in v 6
as far as I can tell the syntax for
"sample_Volume_1" in v6 is:
"sampler volume" and no option to choose which slider it relates to.
I Have tried
"sampler volume 1" and "sampler volume_1"
I do find the wiki useful but it does not give examples.
I'm not giving up just yet. lol
geposted Sun 26 Sep 10 @ 4:20 pm
I have found that the best way to get information about VDJScript is directly in VirtualDJ.
Open the Config window and go to the "Mappers" tab.
Create a new shortcut and then start typing an action.
This is what I just did:
-I typed "sampler" in the action and got a list of VDJScript verbs starting with "sampler".
-Click on "sampler volume" and get this description: "change the volume of the selected sample."
-This doesn't give very much information so I clicked on "sampler stop"
I then got this description: "stop the selected sample. syntax 'sampler stop' stops the default sample. 'sampler 4 stop' stops the fourth sampler slot. 'sampler all stop' stops all samples."
So "sample_volume_1" translates to "sampler 1 volume" ;)
geposted Sun 26 Sep 10 @ 6:24 pm
Ahhhh thank you.
That's a great tip - all working now!
Thanks again.
geposted Mon 27 Sep 10 @ 6:04 am
Thanks all for your help.
I have now finsihed my version of Mixlab now Native 6.X VDJ Script.
All my VU meters work and I decided to only show VU levels when the deck is active. The only thing with the VU meters is that the \"Factor\" is not functional in VDJ Script. It\'s a pity as this would make the VUE meters look more visually attractive.
The beat visuals work, but slightly in a different way visually - but you can still see the beat match - couldn\'t get my head around the \"beat grid\" in version 6, that\'s not to say I won\'t take another look at a later date.
It\'s been a steep curve, but I must admit I enjoyed it.
It has given me encouragement to think about making a script from the ground up. I know there is a tutorial somewhere regarding using photoshop but I can\'t remember where.
If anyone wants a native MixLab v6 let me know and if the rules allow I will apply to have it hosted in the skins section.
geposted Mon 27 Sep 10 @ 8:08 am
