Now available on the controller download section the Vestax VCI-300 MKII + VFX-1 Def & Mappers.
Vestax VCI-300 MKII Def & Mapper
v1.0
First release with colored leds mapped on hot cues and more options added for Virtual DJ 7.
Download -> http://www.virtualdj.com/addons/12082/Vestax_VCI-300_MKII_Def___Mapper.html
Vestax VFX-1 Def & Mapper
v1.1
Led fixed and mapper optimized.
Download -> http://www.virtualdj.com/addons/10746/Vestax_VFX-1_Def___Mapper.html
Created by http://www.digitaljockey.eu staff
v1.0
v1.1
geposted Wed 13 Oct 10 @ 5:37 am
hi cioce
I downloaded both mappers for VCI-300 MKII and VFX-1 for Virtual DJ 7.
I'm using VCI-300 and VFX-1. I use deck 1 and 2 for imputs, deck 3 and 4 for mixing.
I want to control deck 3 and 4 using VFX-1, but I just can't figure out how.
Would you help me out pleaes?
geposted Sat 06 Nov 10 @ 7:51 pm
is there a way you can can email me these mappers, not able to download it :( [EMAIL REMOVED]
[Sorry, contact details are not allowed from unlicensed users.]
Mappers and Definitions are restricted to users with a purchased license.
geposted Sun 20 Mar 11 @ 3:22 pm
thanx
geposted Fri 25 Mar 11 @ 12:27 am
If you want to download the mapper you need a licensed Virtual DJ Professional Full. Just register your serial in your profile to get the download working.
BTW, with any other version the files will not work so it should be an easy thing for you.
Greets, Heiko
Greets, Heiko
geposted Fri 25 Mar 11 @ 3:50 am
The Vestax VCI-300 MKII and VFX-1 are both natively supported in VirtualDJ v7.0.3 Pro: http://www.virtualdj.com/buy/index.html
No mappers are required.
You can try it out before purchasing for 10 minutes at a time in VirtualDJ Home FREE: http://www.virtualdj.com/download/free.html
NOTE: After 10 minutes, Home FREE will revert back to mouse and keyboard control only until you next restart the software.
geposted Fri 25 Mar 11 @ 6:53 am
