Forum: VirtualDJ Skins
Topic: I'm working on a new beauty.
djjbPRO InfinityMember since 2004
Hi,
With the update of vdj7, whe 'skinners' can go out of control. So many things whe can do now.
See below for my next skin. Ow..... maybe you can think with me for a name.
Not finnished but here I have some examples
Best regards,
John
geposted Sun 17 Oct 10 @ 4:22 pm
I guess it's you new TouchScreen version right?
So just call it TouchMe ! hehe
Nice work mate ! If you are closing to release i would be glad to test it with my touchscreen (1280X1024)
BTW. Did you manage to hide browser completely, or with minimum height?
geposted Sun 17 Oct 10 @ 4:27 pm
Hi djdad,
Thanks for your reply. Owyeah! TouchMe can do...
You can test now if you want, just pm me.
The browser is completely gone when you see 4 decks.
<browser pannel="hide_browser">
<size width="0" height="0" />
<pos x="0" y="0"/>
<text font="ARIAL GREEK" size="13" color="transparent" selected="transparent"/>
<options font="ARIAL GREEK" size="13" color="transparent" over="transparent"/>
<widgets font="ARIAL GREEK" size="1" color="#2F302B"
facecolor="transparent"
lightcolor="transparent"
shadowcolor="transparent"
darkshadowcolor="transparent"
highlightcolor="transparent"
trackcolor1="transparent"
trackcolor2="transparent"/>
</browser>
The red text is colored the same as the skin background. otherwise you see "search" at x="0" y="0".
You must see this working, so smooth.
ps: What are those \\\\\\\ in my topic-name?. I didn't type them.
Best regards,
John
geposted Sun 17 Oct 10 @ 11:50 pm
