Forum: VirtualDJ Plugins
Topic: Downloaded sound effects,loaded them. Doesn't work.
I'm using VDJ Pro V.7. I downloaded several sound effects to use on sampler. Some are actually working. Do I have to change anything on the file type?
geposted Fri 22 Oct 10 @ 1:51 pm
JoeyKJPRO InfinityMember since 2008
Refer to the owners manuel to get specifics to an answer, I believe yes there are some file types that would have to be converted..
Good Luck,
Joey...
geposted Fri 22 Oct 10 @ 6:27 pm
