Some of my video's stoped working after 5.2 is there a reason for that.
using vista, or xp or windows 7, that does not seem to be the prob....plenty of memory....it's just switching from 5.2 to any update!
Thanks....
Thanks....
geposted Mon 25 Oct 10 @ 10:59 am
oh and by the way I can convert them but I HAVE TOO MANY TO CONVERT....
THX
THX
geposted Mon 25 Oct 10 @ 11:00 am
Convert to what, what format are they in now? Stopped how? Don't load, don't play, play for a few seconds?
geposted Mon 25 Oct 10 @ 10:18 pm
I also have the same problem and posted that with Frank yesterday.....
what it is they are vob files when we load them in 5.2 they work fine,.....but after 6 and above will not play!!!
when we load them they will not load but come up video....
when we go to browser a=into the file info....the bottom line says
impossible to open...
THX
THX
geposted Tue 26 Oct 10 @ 11:40 am
when we convert to avi, they work fine (THX)
geposted Tue 26 Oct 10 @ 11:41 am
It sounds like the path to that file has been lost, but you re-aquire it when you convert. Try config, and browser and fix the drives. I have lost some paths, but it is not because of vobs, because most of my vids are vobs. I have upgraded and do not have this problem.
geposted Tue 26 Oct 10 @ 1:56 pm
will try THX
geposted Tue 26 Oct 10 @ 2:24 pm
geposted Tue 26 Oct 10 @ 3:11 pm
I did try "Fix Database" did not fix the problem.....but THX for feedback!
still need help!
still need help!
geposted Tue 26 Oct 10 @ 5:15 pm
Did you do all three of the options, fix, clean, and I forgot the other one? In Windows, verify the file is in the folder it says it is. In VDJ, reset that folder as favorite and try. I forgot to ask, does it play ANY vobs?
geposted Tue 26 Oct 10 @ 5:58 pm
Will try only did fix I do have other vob files that work
geposted Tue 26 Oct 10 @ 6:15 pm
So we know it is not the vob codec.
geposted Wed 27 Oct 10 @ 10:25 am
no luck still can not get the vids to load into vdj after ver 5.2 thx for trying any other ideas?
geposted Fri 29 Oct 10 @ 2:27 pm
I play vobs all night long, and do not have this issue. There has to be an issue with the database. I see you went from a 5 database to the 7. Can you try to re-install 7 again? I am running out of ideas, but know that a re-install has solved some of my issues. Don't give up, because if it works for me and others, then it will work for you.
geposted Fri 29 Oct 10 @ 2:47 pm
Thanks
geposted Fri 29 Oct 10 @ 4:40 pm
did anyone find the fix for this??? still doesn't work..
geposted Wed 03 Nov 10 @ 6:31 pm
still waiting
geposted Thu 04 Nov 10 @ 7:04 am
have you tried navigating to them manually (going through computer > drive > dir > file) instead of searchin for them
to pinpoint if vdj is having trouble searching for them
geposted Thu 04 Nov 10 @ 8:43 am
