I bought this PC configuration is that .
Computador All In One PC MSI, Intel Atom, 1GB, HD 160GB, LED 18,5", Touch Screen, DVD-RW, Wireless - Windows XP
see the link below
http://www.walmart.com.br/Produto/Informatica/Computadores/MSI/99824-Computador-Intel-Atom-1GB-HD-160GB-Windows-XP.aspx
see the link below
geposted Tue 09 Nov 10 @ 1:56 pm
Product temporary unavailable.. it seems you bought the last piece..lol ....ok ... . so what is the native resolution for this?
geposted Tue 09 Nov 10 @ 5:00 pm
I dont use the jogs for scratching, but I do use them.
geposted Tue 09 Nov 10 @ 8:07 pm
For pitch bending or fine cueing or navigation through the song?
For pitch bending there will be bend buttons
There will also be scratch wave for fine cueing and navigation
You may also use the rhtyhm wave or song pos for navigation.
Jogwheels will need large space in the skin, and will make buttons smaller.
Check your pm.
Check your pm.
geposted Tue 09 Nov 10 @ 8:13 pm
Gotcha!
geposted Tue 09 Nov 10 @ 8:43 pm
