Does anyone know if you can create a button to go on a skin that would enable the external monitor for VDJ instead of having to check it in the settings box? Is it possible?
geposted Sat 06 Nov 10 @ 11:21 pm
You should only have to check that box 1 time................1 thing you could do is set the to not turn on until you turn it on. Like some people have it set to turn on when they load a video. For me I dont do videos every where but I have some hot remixes that are videos and I like to play them with seeing the video so I have it set up to turn on when I click on the main video window (in the skin).
Hope that make sense
Huey
Huey
geposted Sun 07 Nov 10 @ 12:59 am
Unfortunately, there is no such shortcut.
geposted Sun 07 Nov 10 @ 5:45 am
Thanks for the responses guys! Guess I'll have to figure something else out. It's a pain if one of the DJs in the booth unplug the projector from the CPU and you have to go into settings every time to re-enable the output on the projector.
geposted Sun 07 Nov 10 @ 6:40 am
