thats what i ran into last nite had gone from deck 1 to 4 then 3 and tittler still showing the tittle for one and would not do deck 3 ,then #4 wuld not do #2 huh?...Oh and i have my Hercules Rmx pfl"s buttons they way they should be as posted here...http://www.virtualdj.com/homepage/jpboggis/blogs/3702/VDJscript_examples.html as well as the scratch.
geposted Thu 11 Nov 10 @ 9:55 pm
I think there's a few other plugins that wont work with 4 decks either. I thought I read it has something to do with the SDK, whatever that is, lol! I believe its the coding or something along those lines.
Peace Homie
Huey
Peace Homie
Huey
geposted Thu 11 Nov 10 @ 10:37 pm
Older plugins are not aware of more than 2 decks existing - they would be built against the earlier SDK which uses v4/v5 commands to get their information.
geposted Fri 12 Nov 10 @ 12:30 am
thanks scott,figured that.so now what? pm all moderators to update?....:-(
geposted Fri 12 Nov 10 @ 1:46 am
@Tracker have you tried it on a skin that uses that "Left/Right" logic like VDJ's 6 deck skin. It seems like if you use a 4 deck skin these plugins wont work with them. Gotta go to work now so I can mess with the other skins. I havent gotten around to tryin any other skin but mine really, lol!
Huey
Huey
geposted Fri 12 Nov 10 @ 7:30 am
Yeah..again figured thats the issue,but its the 4 decks i use.I can no longer see it in my download page..who made the titler? was it cel?
geposted Fri 12 Nov 10 @ 10:26 pm
