I love that skin. (Just to be clear, that skin, not the four skin version.)
Ha ha ha...
No, really though. Condensed 1.5 is a great skin, but I have not used it since I upgraded to VDJ version 7.0. So can I use that skin without any major issues until an updated version of Condensed surfaces?
Rick
Ha ha ha...
Rick
geposted Sat 13 Nov 10 @ 8:27 pm
Should be just fine.
I used the 800x600 version of it to remote in from my Vaio U70 and it worked a treat!
Keith
Keith
geposted Sun 14 Nov 10 @ 3:54 am
Krad,
So you haven't had any issues at all. That's interesting. I'm thinking that because the skin was designed for VDJ 6 it would have some issue with version 7.0, being that version 7.0 has a lot of new features as well as an updated engine.
Have you used VDJ 7 and Condensed skin at any gigs and still able to take advantage of all the great tweaks associated with Condensed, for a lack of better words (I am writing this after having just woke up this morning)?
Rick
Rick
geposted Sun 14 Nov 10 @ 1:55 pm
You can still use all the ver 6 skins with VirtualDJ ver 7. No problem at all. The only things that you might miss there, is the New Internal Resonanse Filter and maybe some new icons for Netsearch Files and Prelisten if the skin uses Customicons.
geposted Sun 14 Nov 10 @ 2:14 pm
DJDad,
What is the New Internal Resonanse Filter?
geposted Mon 15 Nov 10 @ 10:47 am
Actually its called Resonant .. my bad.
It's a new internal effect. When it is in the middle (50%) it's off.
VirtualDJ7 Skin
VirtualDJ7 Skin
geposted Mon 15 Nov 10 @ 12:55 pm
Is it easy to use and what actually does it do as an, I assume, intended effect?
geposted Mon 15 Nov 10 @ 9:25 pm
CONDENSED has been updated to Version 1.7 - read about it here:
http://www.virtualdj.com/forums/140831/Virtual_DJ_Skins/CONDENSED_1_7_--_great_new_features_for_2011_.html
geposted Sat 08 Jan 11 @ 2:09 pm
