Is there any way in VDJ7 to switch the output between stereo and mono? At a gig last night I needed MONO due to the way the system was set up. I had to edit the advanced sound config that was already set for stereo. when the gig was over, I unchecked the MONO box but all my advanced settings for STEREO were gone and I had to re-configure the entire sound setup again.
any help would be appreciated...
geposted Sat 20 Nov 10 @ 11:05 am
Heres a plugin, I dont understand what it says but here goes, lol! http://www.virtualdj.com/addons/1125/Balance_Stereo_Mono.html
Not sure if this will help
Huey
Huey
geposted Sat 20 Nov 10 @ 11:14 am
I think that plugin is too old.. I need it to work with VDJ7 and the new ADVANCED AUDIO CONFIG
geposted Sat 20 Nov 10 @ 11:39 am
Well it does work with 7 so I would say try it first and if it doesnt work no harm done..............
I Try
Huey
I Try
Huey
geposted Sat 20 Nov 10 @ 3:43 pm
djqwikcut wrote :
... I needed MONO due to the way the system was set up.
What do you mean by MONO? You had only on speaker? or did you want to split stereo sound chanels to left & right to run more decks ?
Could you give us more infos about your setup ?
geposted Sat 20 Nov 10 @ 7:19 pm
i was having the same kind of prob with vdj7 i had my friends cd decks and mixer going through my hercules rmx mixer then out to the monitor but no matter what there was a huge delay from his set up to the monitor the mix was perfect in his headphones but once you put it up it was off terribly through the monitor any suggestions?
geposted Sun 21 Nov 10 @ 4:52 pm
andrew146 wrote :
i was having the same kind of prob with vdj7 ...
.. and you think your prob is relative to the topic's title?
Please open a new topic in the Hardware Forum and post your issue.
geposted Sun 21 Nov 10 @ 6:01 pm
My mixer is STEREO ONLY.. there isnt ANY mono switch so that I can COMBINE left and right channels into LEFT and RIGHT on the outputs so that on the left output you hear RIGHT and LEFT and on the RIGHT OUTPUT you hear RIGHT AND LEFT.
I did an event Firday and what we have setup is ONE XLR cable from my mixer to the DRIVE RACK PA.. then we use the Drive pack PA in MONO MODE to run to th AMP which has ONE SIDE going to the BOTTOMS and ONE SIDE to the TOPS. I have been using a XLR "Y" cable to plug both master output channels from myt mixer to ONE XLR to plug in the master cable to the processor but if I can do this with a click of a button it would be easier (since I forgot the adapter the other night).
in VDJ7 you can click MONO in the advanced sound setup and then change the outputs to MONO but it ERASES all of your stereo sound settings and I dont want to go through that every time I need mono....
geposted Mon 22 Nov 10 @ 8:09 am
I see. Well then, either you have to remember bringing the adaptor with you, or re-setup the Advanced Config every time you dont.
Actually we have asked from Dev Team for future update to implement a sound config save file(s). That will solve your issue.
geposted Mon 22 Nov 10 @ 5:46 pm
