Forum: Old versions
Topic: Sample saving help
jskeetPRO InfinityMember since 2010
hey all im new to the forum, but love using this program! Recently i began trying to save some samples and when i try to reload them it does not work. all help is appreciated!
geposted Mon 06 Dec 10 @ 1:51 pm
Haui70PRO InfinitySenior staffMember since 2008
How have you saved it?
NOTE: By default, recorded samples are not saved for use in subsequent
sessions. To save the sample, use the “Sample Options” menu and select the
“Save…” option.
geposted Wed 08 Dec 10 @ 5:32 am
I take it that this does not apply with the demo, or "free" version of this that came with the mix deck?..
geposted Mon 01 Sep 14 @ 7:12 pm
VirtualDJ LE is limited software and does not support loading/saving samples.
It only allows samples to be temporarily recorded on the fly (These will be lost when you exit the software.)
geposted Tue 02 Sep 14 @ 5:23 am
I got 7 Pro and it doesn't load saved samples from a previous session. How can the samples be saved after closing and opening a new session?
geposted Thu 05 Jan 17 @ 9:34 pm
