Forum: Old versions
Topic: Bass distortion problem when Output=Headphones
Tipsy13Home userMember since 2010
As the title says, i i get a distortion in the bass when i choose the "Headphones" option in Output, the sound is great if i just let it be with one output...
I downloaded the home edition and i know that it does only work 10 minutes...
But i really want to get this program... if i can get it to work...
Soo, does anyone know what to do to fix it?
Im using a Sennheiser USB adapter. I know it works because my friend uses the same external soundcard on his computer...
geposted Sat 11 Dec 10 @ 7:35 pm
Haui70PRO InfinitySenior staffMember since 2008
Some soundcards have not enough power ;-)
You use the 2 soundcard option?
Please tell me your settings in VDJ Config -> Soundcard and Perfromance
geposted Mon 13 Dec 10 @ 7:12 am
If you are using two different sound cards, make sure that they have the same audio properties set in MacOS's Audio MIDI setup (Applications > Utilities > Audio and MIDI Setup)
Set each card to the same sample and bitrate, e.g: 44100 Hz, 16-bit
geposted Mon 13 Dec 10 @ 4:49 pm
djzeviePRO InfinityMember since 2011
Hi i have a simular issue. When I turn up the bass all the way on the VMS4 using virtual dj pro I get bad distortion.
Im using a macbook pro running lion, and my config. is 4 decks advanced:
Deck 1 - VMS4 audio midi device - output 1&2
Deck 2 - VMS4 audio midi device - output 3&4
Deck 3 - VMS4 audio midi device - output 5&6
Deck 4 - VMS4 audio midi device - output 7&8
When I plug an ipod right into it and turn the bass all the way up it has fine bass but not when connect to VDJ!
Help?
geposted Mon 19 Dec 11 @ 8:01 pm
