It is usually easier to reduce the image resolution than increase because there is distorted in a matter of the XML file I use to PADXML will trace the skin does not have the skin resizer version JeremK
geposted Sun 09 Jan 11 @ 10:01 am
Again i repeat it's not a matter of graphics resolution reduce.
The skin is made at 1280X1024. If i use the normal resize (with the same ratio) it will come to 1024X845. In order to become 1024X768, you should reduce the size of the browser, but since there is no browser on the deck screen, this is not doable.
geposted Sun 09 Jan 11 @ 10:04 am
Thank you for the reply I like to know because I learn more with the same answers thank God be with him always enlighten your life
geposted Sun 09 Jan 11 @ 10:08 am
VirtualTouch ver 1.0
Special designed for touchscreens
Turn your touchscreen in to a custom made controler !
Resolution 1280X1024
Uploaded
I will post the link after the approval.
Uploaded
geposted Sun 09 Jan 11 @ 8:05 pm
I love you lol... Can you help me with 1 lil thing?? I want to change the Video enable button to double click so I dont accidentally hit it.. If not I will just disable it altogether... LOVE THE SKIN!!
geposted Mon 10 Jan 11 @ 12:40 am
Open the xml file. Search for action="video" and replace with action="nothing" dblclick="video & true"
geposted Mon 10 Jan 11 @ 8:18 am
Sorry, try this one, it will also make the button to light on when video is active
action="video ? true : false" dblclick="video"
geposted Mon 10 Jan 11 @ 5:01 pm
so far nothing of the skin approval
geposted Wed 12 Jan 11 @ 11:33 am
VirtualTouch v.1.0
now available
Download Link
http://www.virtualdj.com/addons/12532/VirtualTouch.html
now available
Download Link
geposted Mon 17 Jan 11 @ 1:55 pm
Just downloaded it and it gives me "A fatal error has occurred!" When I hit "Recover" it says X:\Projects\rewire\ReWireDLL\Portable\ReWireDLL.cpp(982) : VERIFY failure and then closes and reboots VDJ. Any ideas? All my other skins work fine.
geposted Mon 17 Jan 11 @ 3:45 pm
I'mnot sure. It has to do with Rewire as i see from the error description. Do you use Rewire? What resolution is your touch screen?
geposted Mon 17 Jan 11 @ 4:05 pm
I have Mackie's Tracktion software installed on the same machine that uses Rewire I found out. My touchscreen is 1920x1080.
geposted Mon 17 Jan 11 @ 5:04 pm
Compliment DJDAD,
This is a perfekt TouchSkin for my 23" ACER Home Computer. ;-)
Great Work!
Great Work!
geposted Tue 18 Jan 11 @ 11:12 am
Congratulations on your skin, would have a forecast for resolution of 1366x768
geposted Tue 18 Jan 11 @ 4:18 pm
Yes there will be a 16:9 and a 16:10 version but i can not give you any dates.
@Silberrucken .... About the VirtualKB, why dont you make also visible the numeric and some extra keys like ENTER ? Numeric for example are usefull when you search songs from groups like ub40.
geposted Tue 18 Jan 11 @ 5:02 pm
they are right. however, most wishes are titel wishes. ok enter key is now inserted.
take a look ;-)
http://www.oldies2000.de
geposted Wed 19 Jan 11 @ 6:06 am
I can't open the skin...
r I want to open the skin and vdj leaves east error to me?
That I do?
That I do?
geposted Wed 19 Jan 11 @ 5:27 pm
Try to load the default 2deck skin first and then load VirtualTouch.
Note that this is a 1280X1024 skin, with browser height ZERO, so there might be some missfunctions, when VDJ tries to autoresize (perhaps..)
geposted Wed 19 Jan 11 @ 5:42 pm
Hallo djdad,
IDEA: Create a dopple-skin or a skin for 2 monitors ...
geposted Fri 21 Jan 11 @ 3:26 am
I've done in the past such a skin
http://www.virtualdj.com/addons/9018/Double_Touchscreen.html
Old version, not that good as this one, but you can try.
I might udpate this one too, but it will be for later.
geposted Fri 21 Jan 11 @ 8:48 am
