Forum: Old versions
Topic: BPM and Beatlock problems.
elvertPRO InfinityMember since 2003
Problem 1
VDJ is not calculating BPM correctly. In some songs there is a big difference from the BPM calculated by MixMeister and Virtual DiscoMix for example, and that are correct.
Will you have the problem resolved in the next version ? Do you agree that the problem exist ?
Problem 2
I load a song in Deck A and press PLAY; then I load a song in Deck B , press BEATLOCK ON, and press PLAY. Sometimes the sound hesitates to start or starts like having a flanger effect in the background. What do I do to eliminate the problem ?
Thanks,
Regards,
Elvert
geposted Sat 23 Aug 03 @ 3:01 am
I experiencing the same problems
geposted Sat 23 Aug 03 @ 7:25 pm
