Forum: Old versions
Topic: newbie need help
hello guys,...
I just download virtual dj v3,...and I instaled,..but it said "the procedure entry point DdEntry10 could not be located in the dynamic link library DDRAW.dll"
So,..I just instaled ddraw.dll and d3d9.dll.... why it still can't loaded..?
(windows still warning that "the procedure entry point DdEntry10 could not be located in the dynamic link library DDRAW.dll"..?)
Help me please
geposted Sat 09 Jul 05 @ 7:19 pm
install directX9.0c
wow,...its work :)
Thank you guys for your quick replay...
This d3d9.dll error case should be made sticky.
A lot of people report this. Why not add it to the VDJ faq?
It's in the FAQs. Like second or third from the bottom of the list.
cstoll
It might be a good idea for virtualDJ to check for this on startup and put up a warnng and exit if it's not found.. That is easy to do.
