finally got my software issues straight but now my controller is acting silly. The left jog wheel will not scratch in scratch mode or go back and forward when scratch mode is off...all it does is stop the track while my hand is on it. the Right wheel performs just as it should. am i missing something or is it a defetive unit?
mix track pro
virtual DJ LE
windows 7 OS
thanks , bob
mix track pro
virtual DJ LE
windows 7 OS
thanks , bob
geposted Sat 08 Jan 11 @ 8:02 pm
ttt
geposted Thu 13 Jan 11 @ 1:49 pm
On my mixtrack pro, if i spin d table i here no spinback sound same thing happen when scratching. Help!
geposted Sun 26 Jun 11 @ 5:54 pm
sounds like you have a bad unit, so sorry.
drop by this link, http://www.virtualdj.com/forums/107208/Hardware_Technical_Support/NUMARK_Hardware_Products_(Numark_Rep__Offering_assistance).html
you can get input from a Numark rep there. he will know better than I.
Good luck,
T
Good luck,
T
geposted Mon 27 Jun 11 @ 8:30 am
Smart scratch enabled?
geposted Mon 27 Jun 11 @ 10:21 am
you would have to remap your jog dial to play the backspin effect when you spin it backwards. however, im not too sure if it is possible to map the jogs to varied actions dependent on which motion you input.
eg, having a different action for forward and backwards motion i believe is not possible, however i could be wrong.
geposted Mon 27 Jun 11 @ 12:42 pm
For the Registered Pro user, you'll need to download the Registry Tool and change a setting. You will see a HUGE difference!! Watch my video, its with the Mixdeck but I have tried it with a Mixtrack and it was the same result.......
Hope it helps
Huey
geposted Mon 27 Jun 11 @ 1:33 pm
