Hello Forum,
I'm soon about to buy my virtual DJ gear but, still in the middle of making an decision on what kind of mixer I want. I heard the Behringer Pro Mixer VMX300 USB have some type of MIDI Function to it, is that true? And, can the Mixer control virtual DJ (For an Example: If I move the crossfader to the left/right on the mixer, will virtual DJ respond with the same action by moving the crossfader to the left/right)?
Thank You
Thank You
geposted Sat 22 Jan 11 @ 2:28 pm
The mixer has no Midi functions............meaning you cant control VDJ.
Huey
Huey
geposted Sat 22 Jan 11 @ 3:22 pm
behringer mixers are poop, full stop.
i recently done a lot of research on mixers when i was planning to buy a new one on a budget. from the research i done the behringers were inferior in just about every way possible.
geposted Sat 22 Jan 11 @ 5:08 pm
Bro thats just untrue! Heck you havent even owned 1!! I have the basic VMX300 that I wouldnt trade for the world!! I dont use it now BUT it is my backup............I would battle with the thing even now!! It has curve adjustments for the crossfader and the upfaders, puts out great sound, has the tap kills (which is nice) and its a 10 inch mixer with 3 channels..........I've also had the VMX1000 which was great but I have no use for a 19 inch mixer so I let it go.
Heard the pharse "Dont knock it till you try it"
Huey
geposted Sat 22 Jan 11 @ 5:23 pm
Well I have the Behringer vmx300 mixer and I thought about buying the vmx300USB so I researched it and this is what i found. It does have MIDI sequencer as stated on the 3rd dot. I might try it but if you do before I do please let me know if it works with the crossfader. Thanks
All products by Behringer
Other 3 Channel DJ Mixers by Behringer Behringer VMX300USB 2 CH Dj Mixer With USB
The VMX1000USB, VMX300USB, VMX200USB and VMX100USB DJ Mixers are built to connect directly to your computer and take your music straight into the digital realm. In an instant, these mixers allow you to record and play any digital music file with your PC or Mac computer with no setup drivers required! You also get a massive software bundle to transform your computer into a full-fledged music production and editing studio. Features:
•Professional 3-channel ultra-low noise DJ mixer with state-of-the-art phono preamps
•Built-in USB interface for recording and playback of any digital music file. Works with your PC or Mac computer—no setup or drivers required
•Revolutionary energyXT2.5 Compact BEHRINGER Edition music production software included with feature-rich audio/MIDI sequencer that loads almost instantaneously on all computer platforms
•Massive software bundle includes Audacity vinyl restoration and recording, Podifier and Golden Ear podcasting software
•Intelligent, dual BPM counter with time and beat sync display
•Super-smooth and long-life ULTRAGLIDE faders (up to 500,000 cycles)
•VCA-controlled faders for utmost reliability and noise-free audio performance
•Adjustable crossfader curve for all mixing styles
•Awesome XPQ 3D stereo surround effect
•3-band kill EQ (-32 dB) and precise level meters with peak hold function
•Monitor function with PFL/output balance control and Split option
•Automatic talkover function with dedicated Depth control
•Microphone input with studio-grade ULN technology
•Professional Crossfader reverse switch
•Front-panel 3-way Kill switches with revolutionary keyboard-like tap and hold action
•Gold-plated RCA connectors for highest signal integrity
•High-quality components and exceptionally rugged construction ensure long life
•Conceived and designed by BEHRINGER Germany
geposted Mon 07 Feb 11 @ 10:52 pm
Bro it will not work..............the usb part is only there for recording. No where does it say anything about being or having MIDI CAPABILITY which is what you need.
But if you wanna waste your money go ahead.
Do your research kids
Huey
Huey
geposted Tue 08 Feb 11 @ 2:50 am
If you read the description I posted about the 3rd or 4th Dot down it says it is MIDI capable and connects to almost any interface. I have one on the way that Ive just ordered. Should be here in about a week and I will keep you posted.
geposted Mon 14 Feb 11 @ 11:32 am
Ok I wont say I told you so, lol!
"BEHRINGER's new VMX Series DJ mixers have built-in USB connectivity, allowing DJ's to place MP3s in their mix or send their original creations directly into their computers. These mixers require no special drivers, and include a software bundle with energyXT 2.5 BEHRINGER Edition music production software."
No midi control, its just a soundcard that's it..............
Huey
Huey
geposted Mon 14 Feb 11 @ 11:40 am
I'm just going to try it to see what the outcome will be.. It has a 30 day money back guarantee and a warranty. If I don't like it i will return it. I will follow up just to let people know if it works or not though.
(Revolutionary energyXT2.5 Compact BEHRINGER Edition music production software included with feature-rich audio/MIDI sequencer that loads almost instantaneously on all computer platforms).
I have also included the website that I found more information on. The paragraph labled Super software says "This amazing DAW (digital audio workstation) makes it easy to manipulate your audio and MIDI files, turning song ideas into stunning CD or web-ready recordings."
So as soon as I receive it I will be sure to let you guys know.
http://www.behringer.com/EN/Products/VMX300USB.aspx
geposted Mon 14 Feb 11 @ 9:23 pm
djenergizer79, what's the verdict? Does the crossfader work with VDJ?
geposted Sat 24 Dec 11 @ 8:24 pm
No it wont work. Its not that kind of mixer............
geposted Sat 24 Dec 11 @ 10:02 pm
Thanks.
geposted Sat 24 Dec 11 @ 10:24 pm
I just got DDM4000 and it's a five star mixer for the price!!! (around $450).. Also, midi capable!
geposted Sun 25 Dec 11 @ 11:53 am
Yeah the DDM4000 looks great but more money than I can spend right now. Are there any other mixers that can mix hardware(turntables, drum machines etc) that are midi equipped to run VDJ? On the same note what controllers with decks and built in mixer also can be used to mix hardware? I know the Hercules DMX can but the platters are too small. I'd like something like my Numark Mixtrack but that integrates a hardware mixer. Also something that isn't garbage build quality like my Mixtrasck is.
geposted Sun 25 Dec 11 @ 12:08 pm
Morning all (when your a DJ it's always morning, cause we all get in at Silly O.clock)
I'm a Video DJ and have been for in the industry for over 30 years, being a DJ & now DVJ has taken me round the world, however i'm starting to feel it's time to simplify my set up
So my DJ mate has recommended VDJ which i now have bought and do like (Very much) however i need advise on what would be the best set up.
My current set up is Pioneer SVM 1000 & 2 x DVJ 1000 and using VDJ via a converter into one channel of the SVM as a back up, this works well but is a bit of a faff to set up for small gigs.
Tom (my mate) use's a Denon MC 6000 which is good , but to me it looks like a toy with the small jog wheels. Im tempted to buy the Numark NS6 as it has large jog wheels and all the bits. I would use this for smaller gigs. But keep my SVM & DVJ's for corporate gigs.
I recently bought Rane SL3, matrox dual2go & 2 extra video converters to try and link Virtual dj and my SVM & 2 DVJ's but i was getting lag with the time codes. So I have ditched that idea (Sorry, selling is not permitted in the VirtualDJ forums - Please see: Forum Rules)
So any ideas to what midi unit i should get.
Thanks in advance
Simon P
www.simonp.co.uk
Thanks in advance
Simon P
www.simonp.co.uk
geposted Sun 12 Feb 12 @ 8:49 am
The VMX300 USB has a mic input. Does anyone know whether VMX300 USB's mic input has phantom power, so that I could use the unit in the place of an audio interface to connect my cardioid XLR mic to the computer, via the USB interface?
Please let me know you thoughts, or from experience of using the VMX300 USB. Thanks.
geposted Sat 02 Jan 16 @ 3:55 pm
I heard the Behringer Pro Mixer VMX300 USB have some type of MIDI Function to it, is that true? And, can the Mixer control virtual DJ (For an Example:????
Ali
Ali
geposted Wed 20 Apr 16 @ 11:40 am
