Crashes my computer every time.
geposted Sat 29 Jan 11 @ 9:20 am
So... are you complaining to Fierogt87 about his skin? Or are you saying that you cant access VDJ because every time you open it, Intuition 3.0 crashes your computer? If it does, then i suggest this, the second post. http://www.virtualdj.com/forums/140147/Virtual_DJ_Skins/Invalid_skin_file_(error_line_0_in_the_xml)_Solved.html
geposted Sun 30 Jan 11 @ 11:07 am
Did you install the included font, "Amigaforever"? it's included in the zip file. I've gone over the code, but i can't find anything wrong... can you give me any details?
geposted Wed 02 Feb 11 @ 5:55 pm
anyway, i updated the songpos elements and reuploaded... try it now?
geposted Wed 02 Feb 11 @ 7:30 pm
