Topic: djconsole & tt with tcv simultaneously.
dj fumaHome userMember since 2005
Can we work with Djconsole & Turntable with Timecoded vinyl simultaneously?
If so, then how can we get it all inter-connected.
Do i have to connect my Turntable with ASIO soundcard or is there a different scenario
when connecting Djconsole too.
geposted Wed 20 Jul 05 @ 1:58 pm
Depends on what purpose you want for the Console.
You can only use 1 TCV with the DEMO version. (I think).
TCV's require ASIO, yes. Maya 44 USB is a recommended sound card. (READ/SEARCH OTHER THREADS ON THE FORUM!)
geposted Wed 20 Jul 05 @ 2:26 pm
you can....
but as said, you need the full version :)
You can use Hercules AND timecode at the same time... but its recommended to use the controller part of hercules only, and timecode through another soundcar (maya 44 for example)
One reason being that Maya got 2x stereo in (for two turntables) and Hercules only one in.
And Hercules also dont have a leveler for input, so it works better with Maya
geposted Wed 20 Jul 05 @ 3:02 pm
