Forum: VirtualDJ Plugins
Topic: How to open downloaded effects (Mac)
Ok, so I just got the Hercules RMX and it came with VDJ 5 DJC, now from the community page I downloaded some effects. How can I uses them and open them into my VDJ? It seems like VDJ 5 DJC is very very basic, it says I can use a 20day free trial for VDJ Pro but I wan't to wait off to use that until I get more comfortable with the software.
So again
How to open downloaded effects and play with them in my VDJ version 5 DJC?
Thanks so much.
geposted Thu 10 Feb 11 @ 4:36 pm
Sorry, the software that you received with your DJ Console is a limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.)
To be able to use custom skins, effects and much, much more you will need to upgrade to VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
Your Hercules RMX entitles you to a significant discount off the cost of upgrading. To receive this, please go to http://www.virtualdj.com/buy/index.html
geposted Thu 10 Feb 11 @ 5:58 pm
