Forum: Old versions
Topic: Help...
VOXDCPRO InfinityMember since 2003
I just finished recording a cd with virtualdj and when i heard it, there seems to be a problem where i cut each tracks. Instead of going smoothly to the next track, its skips exactly where i cut it. I have easy cd creator 5 and i know thats not the problem, because i use it when i use atomixmp3 and it works fine. What should i do???
Thanx
geposted Mon 25 Aug 03 @ 11:40 pm
stuxxxPRO InfinityMember since 2003
Hi there
have u got autocut disabled in the recording options menu?
If not, that would cut each track!
Hope this helps
Stu
geposted Tue 26 Aug 03 @ 1:47 am
also do you have the "at once" feature enabled to take the 2 second gap away?
geposted Tue 26 Aug 03 @ 2:11 am
My autocut is disabled and its not really a 2 second gap, its more like its skips a beat. I know when recording my cd that i should choose the option disk at once so that i dont have the 2 second gap. Its really annoying because thats the most important part of the cd, when i am mixing and cuting into a new track, so its sux that it happens. I hope someone has a solution (please dont say not to cut, because i need tracks in my cd)
Thanx
geposted Tue 26 Aug 03 @ 3:16 am
kickoHome userMember since 2003
just disable auto cut track, and burn with nero, it great cuz u can cut the tracks all u want with no sound space, skip, or anything! just a smooth mix with tracks
geposted Tue 26 Aug 03 @ 6:47 am
MathewPRO InfinityMember since 2003
Have the same problem with Easy CD Creator.
I think the Software is not able to do It the right way.
By Mathew
geposted Tue 26 Aug 03 @ 1:45 pm
