Forum: Music discussion
Topic: Way to Edit Recordings?
Whats good everyone! Just a simple question I hope to get figured out, does anyone know if I can edit my recordings instead of it recording as a single track? For example I'm looking to clean up maybe any miss timings in Acid Pro, just to make sure it sounds flawless, but all I'm getting right now is a continous waveform. Thanks for any help!!
geposted Mon 28 Feb 11 @ 3:30 pm
For sketchy transitions, the only thing I can think of apart from re-recording would be to get Audacity, which is a free and powerful sound editing program. Then you can record a clean transition separately and splice it into the mix.
geposted Tue 01 Mar 11 @ 10:43 am
Thanks, I've used Audacity before and your right powerful little thing, however you would have thought there could have been something a tad easier in a way to let you edit, anyone thanks for the reply. Maybe something to the Atomix team wishlist!!
geposted Tue 01 Mar 11 @ 11:01 pm
how aboutbreaking it up into individual tracks?
geposted Wed 02 Mar 11 @ 7:08 pm
You're looking to produce tracks, VDJ is great software but not really made for producing music. If you're looking to clean up sketchy transitions, why not try throwing a sample over top of the trans?
Check this link out for production software. Very powerful tool as well http://www.mackie.com/products/tracktion3/
geposted Wed 02 Mar 11 @ 8:38 pm
