I had allot of ideas for the VDJ 7 4 deck skin. I mostly wanted to add some features and gear it more to controller/time code users. Check my new skin out Here
I am pretty happy with it but would be open to new ideas. Feel free to reply with suggestions. Enjoy
geposted Wed 02 Mar 11 @ 10:37 pm
will check it later on
geposted Thu 03 Mar 11 @ 5:50 pm
just downloaded it bro....sounds sweet...Im doing a few mods on this skin aswell...(more on that Later)...will Report!
geposted Fri 04 Mar 11 @ 7:11 pm
maybe can do with 2 skins!! is posibble!!! 1024*768!!
geposted Fri 04 Mar 11 @ 8:27 pm
For now I am just working on bugs and new functions. 1200x800 is the most common widescreen (that I can see) for most laptops. It actually is not the full resolution of my gig machine. I may do others later but with the fast skin resize in VDJ and the Skin resizer tool, I figure those are best options untill I get a final layout right and bugs worked out.
geposted Sun 06 Mar 11 @ 8:40 pm
Used the skin resizer tool for the first time last night (bought a while ago) and made a 1600x900 version of this skin. Which is what my main gig machine is.
With that, I found some graphics alignments that needed to be made to the 1200x800 (off by 1 or 2 pixels). In the conversion they were further off causing me to notice it. Then I might tackle the 1024x768 if the 1600x900 works well. Which I will test more this week.
geposted Mon 07 Mar 11 @ 9:06 am
nice i like it, great idea adding l2's ce panel to it,
wish i had thought of that for the 2 deck mod i came up with lol !!
like the idea of it keep up the good work
geposted Mon 07 Mar 11 @ 1:19 pm
In all fairness, the center of the scratch panel is the same as the stock one. The VU meters and cue counters are from his. But now they shift with the deck. The VUs change color and the cue counters refect the selected left and right deck.
Did you right click the Player and Effect buttons on each deck for hidden panels. They are MINT if you use video! Not to mention a 1600x900 version soon to be published, with a few minor corrections.
Tried the 1024x 768 resize of the 1200x800 skin. I am gtting some errors starting with line 13. That may be harder to pull off than I am capable of. But I have over come plenty before. Just stumped for now.
Thanks for the support.
geposted Mon 07 Mar 11 @ 2:36 pm
Submitted the 2.01 update tonight. Small things (spoken about earlier) but I did add 1600x900 resolution! 1024x768 is still not working for me yet, sorry. I will be looking into it again soon.
geposted Tue 08 Mar 11 @ 8:57 pm
