Forum: Old versions
Topic: How to change tempo without altering pitch?
Im currently using VirtualDJ Pro v7 (b342) and am wondering how I can setup the software so that whenever I change the tempo of a track on the deck, the pitch wont go low or high if I reduce or increase tempo?
Can anyone offer some specific guidance on how to permanently enable keylock with Version 7?
EDIT: Sorry, this was a bug for a few software starts, enabling the keylock now stays on permanently:)
geposted Mon 14 Mar 11 @ 7:58 pm
So whats happening is when you speed up the track the voices get all chipmunk right? If so turn on the "Key Lock"
Huey
Huey
Yep, that works now, initially it didnt work but now it mysteriously does. This same thing happened with 5.2 Pro but playing with the semitones allow it to stay on... thanks for the response:)
major issue.. mine is like not workin at all... i push keylock on my ns7 and directly on VDJ7 and it does not work... help please
Make sure that you have not chosen 'Pure Scratch' for CONFIG -> Performances -> Master Tempo.
Pure scratch does not allow master tempo/keylock, as indicated by that option.
