Vista home 32bit
vdj 70.3
Vestax VCM-100
Drivers are up to date..
Crossfader moves around by itself. This all started about 3 updates ago (vdj7)..
Nothing need to be in the decks for this to happen.
When I move the Crossfader to the right player only, the Crossfader will jump to the middle or ¼ and start moving back and forth like its possessed. Make it very hard to mix.. The “video Crossfader Automatic” and “Fade to Black on Volume Slider” are disabled...
I just upgraded the Primary Hard Drive with a new 2tb drive to see if there might have been an issue with the OP but still happens.. Happens with all file types..
My BACKUP roadcase is also suffering from a similar issue but it's the VALUNE slider that moves..
It doesn't jump to a position like above, it just slightly up and down.. it's all nuts..
HP laptop Vista Home 64bt with a Hercules RMX..
vdj 70.3
Vestax VCM-100
geposted Sat 19 Mar 11 @ 11:58 am
When the VCI-100 is unplugged does it still have this issue? Could it possibly be the CF curve setting on the controller?
Regards,
AC
Regards,
AC
geposted Sat 19 Mar 11 @ 3:50 pm
Sounds like it might be dirt in the crossfader causing random MIDI signals to be transmitted. Try giving it a good wiggle fully left to right a few times and see if that clears it - sometimes my upfaders get a little crackly, particularly if they haven't been used lately, and that tends to cure the problem.
geposted Sat 19 Mar 11 @ 8:55 pm
thank you.. but yes blue it out with canned air when i do matanace on the system.. but remember,, its a freaky thing that i have on two systemes. with two different controllers.. one system on a laptop and the other is a pc,, yes they are two different slide pods but still the same reaction,, there are a couple of threads posted with this issue but no resolve
geposted Sun 20 Mar 11 @ 3:06 am
Regards,
AC
Regards,
AC
thank you
as i said,, two different systems,, same type of issue but the pc is more president.. and to answer ur question,, if the controller is not utilized then the issue isnt there,, BUT,, ant that's BUT, My back up system has a rmx and it a laptop.. the issue is with the volume on the right deck.. it seems to related to just the right side
geposted Sun 20 Mar 11 @ 3:14 am
i would love to think its as easy as just the controller or pc/laptop or OP.. i really have much more trying thing to attend 2...
two completely different setups and a issue with a slide pod.. there are two other threads relating to this but no resolve..
Thank you for you responce
geposted Sun 20 Mar 11 @ 3:27 am
i could really use some help with this.. tested it on 4 different laptops and a pc. my pc i use all the time its the crossfader.. the laptops the volume or pitch jump up and down continuously.. all issues are only on the right deck.. two different rmx an a v-100..
geposted Wed 06 Apr 11 @ 12:46 am
really,, no help at all
geposted Thu 07 Apr 11 @ 6:21 am
did you ever get it resolved?? i having same issue
it started today
if i slide the sider to left or right it doesnt automaticly slide to center but if i push it all the way to left or right then VDJ austomaticlly slides to the center
im using Denonc MC6000 with a PC laptop running win 7
it started today
geposted Sun 09 Mar 14 @ 11:12 am
Turn off the auto crossfader function.
geposted Sun 09 Mar 14 @ 11:48 am
Having the same problem, vdj 8.1 with numark Mixtrack pro 3
geposted Wed 20 Jul 16 @ 7:10 pm
How old is your unit, are you familiar with the term 'fader bleed'
geposted Wed 20 Jul 16 @ 7:41 pm
Not old at all a few months and it's bleeding like it's been sliced
geposted Wed 20 Jul 16 @ 11:19 pm
When I started we used knobs
Dials bleed too after a while, either it's fader bleed or floating earth/ground.
Its HW at fault.
Its HW at fault.
geposted Wed 20 Jul 16 @ 11:38 pm
