Forum: VirtualDJ Skins
Topic: It helps in the skins.
DJKichosPRO InfinityModeratorMember since 2006
Since I put this the time in the skins, see the image.
<textzone chan=\"1\">
<size width=\"78\" height=\"20\"/>
<pos x=\"429\" y=\"63\"/>
<text font=\"arial\" size=\"20\" color=\"#0970ef\" align=\"center\" format=\"%Pspent\"></text>
</textzone>
geposted Fri 25 Mar 11 @ 3:40 pm
Do you mean that it shows always 00:00.0 ???
geposted Fri 25 Mar 11 @ 3:53 pm
Yes, I want to put the time of the song in setback:
6:00, 5:00, 4:00, 3:00, 2:00, 1:00, 050:00. 000:00
geposted Fri 25 Mar 11 @ 6:18 pm
I'm afraid you're not being very clear
if you want the skin to display the total length of the song at all times use the %Ptime tag in the textzone field
if you want it to display the time "elapsed" use the %Pspent tag
if you want the time remaining in the song use the %Pleft tag.
The capital letter P between the quotation mark and the percent sign is to makethe time reflect correctly any pitch changes made.
geposted Sun 27 Mar 11 @ 10:48 pm
oops i forgot to mention, we sorted out through msn with Kichos. It's true his English are not so good and it took me a while to understand. He wanted to display the remain time instead of the elapsed.
geposted Mon 28 Mar 11 @ 5:41 am
oh, cool
geposted Mon 28 Mar 11 @ 5:22 pm
