Forum: VirtualDJ Plugins
Topic: Novation dicer help!
Hi im kinda new to this, i use an american audio vms4 to dj, but i just bought some novation dicers as i seen there was a map and definition available to download on the site. i downloaded it but have no clue how to implament that download into virtual dj pro7??
help!!!!
geposted Wed 30 Mar 11 @ 5:06 pm
Put the mapper file in Documents/VirtualDJ/Mappers and it should just work (:
The Dicer is already natively supported in the latest VirtualDJ Pro - You don't need to install any mappers, unless you are using Windows XP (See the instructions included with the downloadable mapper for details on how to get it to work on XP.)
Plug it into a USB port, let Windows find it and install the drivers, open VDJ!
Should be good to go! I love mine, they work awesome.
AC
Got them working! cheers guys, just had to update my vdj. cheer
