Hey
i tried to do something new???!!! :-)
I use an VCI 300 and with 7.0.3 you can use the Microphone as well.
Now i tried to use it as an seperate channel (linein for deck 3) so i can use all effects & Equalizer and other VST effects to sound littlle better
and it works perfekt
but i do not need the 3rd deck.
at the moment i use TCmania 3 decks...for DJing i like the 2 Deck varitaion of this skin..
Now what i wanted to know is can somebody create an 2 deck skin with an special line 3 fader and eqalizer panel
an button to activate the action "deck 3 linein 1"
an button/flashlight/higlhited button just shows if any effect is activated on this deck.
This may be Interseting for some of the Radio DJS too
Thanks from Germany
Thanks from Germany
geposted Tue 05 Apr 11 @ 9:45 am
What is your resolution? I don't have time at the moment to build such a skin, but i will give you a quick solution.
geposted Tue 05 Apr 11 @ 11:11 am
Thanks
my resolution is 1366*768
Do you think it will interest others too? I think so..
Greets
Lucky
Greets
Lucky
geposted Tue 05 Apr 11 @ 1:24 pm
have a play with dj dad's virtual touch skin.
Its based on 2 decks plus a hidden 3rd.
Look on the Decks panel, in the center tabs..
geposted Wed 06 Apr 11 @ 6:52 am
Ok, i will add this to my todo list. TCmania 2 decks + 1 hidden with a few extra buttons.
As Mark said, VirtualTouch is such a skin, but builded for touchcreens, large buttons, and browser to a second screen (panel). But the resolution of that skin (1280X1024) will not fit to yours i'm afraid.
geposted Wed 06 Apr 11 @ 7:53 am
Maybe have an idea :-)
on TC mania 2.3 u can switch the MAIN WINDOW..may there can you put the "hidden panel" so you have enough space..
and i dont know so much about skinning but think that is an easy way and not to much work ....
but take your time ...
i can work at the moment, but you making my life just easier..:-D
THX
THX
geposted Wed 06 Apr 11 @ 10:05 am
