Forum: Old versions
Topic: MACBOOKPRO//MIXTRACK PRO SETUP
Hey everyone-
I recently purchased a Mixtrack Pro for VirtualDJ.
I installed the LE that came with it, but it was expired upon installation because I had a Hercules RMX...so I upgraded to VDJ7.
I plugged the controller in via USB and am getting no response at all.
Is there anywhere I should be looking in the configuration or options to assign the controller to act?
I have been able to get audio out of the headphone jacks, but not responsive in using it as a controller.
The instruction manual with the mixer offers software instructions for every other program(Traktor, etc) but NOT Virtual DJ.
Anyone else have this issue?
Plz help.
Much appreciated.
geposted Thu 14 Apr 11 @ 2:12 pm
It worked for me right out of the box..
I would check under config and make sure the mixtrack mapper is active and not just the keyboard one.
That would be the first thing to check..
geposted Thu 21 Apr 11 @ 10:32 am
i'm having same problem any solutions??
geposted Sat 14 May 11 @ 10:26 pm
have any of you figured it out? I just bought a mixtrack pro and my mixtrack pro is not responding to virtual dj
geposted Tue 14 Feb 12 @ 6:08 am
geposted Tue 14 Feb 12 @ 8:32 am
