Forum: Old versions
Topic: virtual dj crashes?
ok guys whenever i try to open virtual dj home free 7 it gives me the msg '' virtual dj has stopped working properly ''
idk why this is happening ...
btw im using windows 7 if you guys can help .. pls
geposted Sun 24 Apr 11 @ 11:08 pm
This can be caused by any number of reasons. Try uninstalling an re-installing the software (might be a bad download, it happens) to see if it makes a difference and go from there.
geposted Sun 24 Apr 11 @ 11:23 pm
This is not a software crash. Its a windows crash application. Make sure you update your OS and drivers.
geposted Mon 25 Apr 11 @ 5:34 am
