Forum: Old versions
Topic: Dj Sample Loops(Mac) HELP!!!!
well i have a macbook pro and i want to download some sample loops like "1,2,3,4.vdj" but when i download the file it seems like its not the right type of file for the mac and vdj will not read it. i want sample loops desperately, its what gets the crowd pumped like the sirens and so forth.
so if anyone has downloaded samples for the mac from the virtual dj plugin area with no problem please respond asap i need the help.
geposted Mon 25 Apr 11 @ 7:52 pm
To load new samples on Mac, please do the following:
(1) Download the appropriate samples from the samples download area http://www.virtualdj.com/addons/samples.html and save these in an appropriate folder on your hard disk, e.g: /users/YOURNAME/Documents/VirtualDJ/Samples or /users/YOURNAME/Library/VirtualDJ/Samples for new installations of VirtualDJ v7.0.3
NOTE: Do not try to open the sample file. Save it to disk only.
(2) In VirtualDJ, go to the Sampler section.
(3) Click on the bullet button to the top-right of the sample slot you wish to load a sample into. Choose Load from the pop-up menu.
(4) Browse to the above location where you saved the samples and choose the sample you wish to load.
how can i put more than 12 samplers? thanks!
how can you add your voice drop to the effect like flangr on vd7 and Hercules RMX
