Forum: Old versions
Topic: please help :)
Hi there
I am using hercules dj trim 4&6 as a USB interface, 2 serato vinyl timecode, 2 Numark turntables, Virtual dj 6 LE software (comes with Hercules trim), and laptop (windows 7, 4GB, 2.53 GHz)
My problem is that i can't get 100% signal on Deck B !!! and when i spin the left timecode vinyl (deck B) back the waveform (on Vdj software) goes forward instead of going backward !!!
for people who r using hercules, have you ever had such problems ? if so, how did you get them solved ???
I am desperate for a help
geposted Thu 28 Apr 11 @ 8:22 am
If you cant get 100% signal from a deck, then try to troubleshoot. Swap turntables, cables, cartridges , until you locate what is causing this issue.
geposted Thu 28 Apr 11 @ 9:13 pm
I got it all sorted out , all good now ... cheers mate :)
geposted Sat 30 Apr 11 @ 9:06 am
