In a previous post I stated I was having issues with missing iTunes music in VDJ 7.0.3. Anyone know where I can download 7.0.2 so I can roll back and see if the problem persists?
geposted Mon 02 May 11 @ 11:30 pm
Go here and ask, http://www.virtualdj.com/contact/index.html , I'm sure they'll help you out.
Huey
Huey
geposted Tue 03 May 11 @ 12:12 am
Please read this helpful thread http://www.virtualdj.com/forums/128627/MAC_Version_Technical_Support/Change_Path_of_iTunes_Library.html
geposted Tue 03 May 11 @ 9:46 am
Rolling back to 7.0.2 fixed it. Thanks for the link!
Just for the record, here's what I was seeing.
1. All of the files are MP3 audio and MP4 video stored in an iTunes library and sorted in iTunes folders.
2. All of the music shows up, is searchable and plays perfectly in iTunes.
3. Some of the music and videos are showing up as normal in VDJ.
4. Most new music were not showing up either in searches or when browsed to in iTunes folders in VDJ.
5. Prior to downgrading, I did try a backup VDJ database with no luck.
6. System config - Windows 7 64bit, dualcore 3.0ghz, 6gb RAM.
geposted Tue 03 May 11 @ 8:02 pm
It seems that is related to that / issue with 7.03. You can still run 7.03 if you want to. You need to install 7.02 and 7.03 to different folders.. Read here... http://www.virtualdj.com/forums/145969/General_Discussion/Skins__Addons_Won_t_Install_with_Version_7_03.html
If you need any help on how to follow those instructions let us know. The above topic is not only solving skins and plugins issues. It is related to the Home Folder of VirtualDJ.
geposted Tue 03 May 11 @ 10:12 pm
