Forum: Old versions
Topic: NUMARK NDX400 AND BEHRINGER DJX 750 QUESTION
Hey, im new to this forum and i ordered some equipment because i wanted to get in to djing. I had a 800 dollar budget and i ordered a Newmark NDX400 (2 of them) and a Behringer DJX750 mixer. I wanted some advice on how to set up my equipment to work with VIRTUAL DJ 7. I came up with some idea's but dont know if they'll work or not since I dont have my stuff yet. Please feel free to give me some advice on how to improve or change this setup casue it might not even work. Thanks in advance :)
OPTION 1:
http://i1081.photobucket.com/albums/j352/bonemantis/Untitled-1.jpg
OPTION 2:
http://i1081.photobucket.com/albums/j352/bonemantis/Untitled-2.jpg
geposted Thu 05 May 11 @ 7:33 pm
To be able to use these CD players with VirtualDJ using timecode CD's ( http://www.virtualdj.com/products/timecode/cd.html ), you will need a proper 4-in/4-out ASIO sound card such as Hercules DJ Trim, Native Instruments Audio 4 DJ / 8 DJ, ESI Maya44 USB, etc. and the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
A better choice would have been NDX-800 which are MIDI controllers and can control the software directly without the need for timecode (You would still need a 2 out (or more) DJ sound card such as Numark DJIO or Native Instruments Audio 2 DJ.)
can you tell us how to set it up
