Forum: Old versions
Topic: HERCULES RMX LIGHTS WON'T STOP BLINKING!!!
i've had my hercules rmx for a few months now, and until now its been all fine. but all this week, i'll plug it up, and it won't stop blinking. then on vdj it'll say that it can't find the controller. can someone please help me?
Thanks.
geposted Sat 07 May 11 @ 9:09 pm
Hi please help, I have switched to my new 13" Macbook Pro and none of the above is solving the problem of "Console not detected".
I updated the drivers and latest versions of VDJ. I also tried manually detecting as outlined in the pdf doc above but nothing detected.
I have VDJ Pro Full latest and also virtualdj_djc installed on my mac.
The lights are still flashing.
If none of those suggestions work, I would try un-installing, rebooting then re-installing. Hope this helps.
Thank you worked a dream!
I had this same problem before, but my problem was that the USB cable had gone bad.
So, for anyone else who has this problem and none of the other options worked for you, try changing your USB cable (they go bad sometimes)
