Forum: Old versions
Topic: Virtual DJ & CDJ350 Problems
So i got this problem: Everything is working fine while having the CDjs connected to my VirtualDJ. it detects both the devices, all the volume, tempo, beat loop works fine thanks to the good mapping. BUT i can only the get the sound to come out of one CDJ. Meaning that the music from noth decks comes through the righthand CDJ.
Any solutions?
Thanks!
geposted Wed 11 May 11 @ 2:13 am
What is your set up like? Both your CDJs are connected via USB right? because I recall in your other thread that only one was connected
Do you have an External Mixer? If so, then your set up should be similar to mine. Input: None, output: External Mixer, Soundcard: Pioneer ASIO
Yes, i have both connected now. Got no idea how to solve this :(
Same Problem here.
I had the same problem, and after some config tweaking i got it right. Try this:
1) on your cdj press and hold the "display" button for about 1-3 secunds, use the whele thing till you get to "MIDI CH"(by defualt all cdjs are on channel1), make one of your players to use CH2.
2)now, in vdj go to "sound setup" under outputs you will need to use "advance config", now press "advance config". Choose "Deck 1 - speaker(Pioneer cdj-xxx). Add a new on( plus sign) and do the same but with "Deck2 - speaker(2-pioneer cdj-xxx)
This worked for me and my setup. Hope it will for you guys also.
