Forum: Old versions
Topic: Cueing problem, Please help
I am getting a distorted noise coming through the headphones whenever I try to preview the next track. At first I believed it to be my audio interfaces fault(m audio fast track pro) and I first noticed it on ableton live not vdj. So i purchased the numark dj io and I still have the same problem.
While looking through the forums I found a few ways to configure vdj and the soundcards but not of them got audio from the master or cue except for the asio driver and I would only get audio(distorted) through setting the headphones to chan 3 and 4 even though the dj io doesnt have a output 3 and 4.
I currently have vdj 7 on a 64 bit windows 7 laptop but I had a 32 bit windows vista laptop when I first had the problem with the fast track pro. I've researched this problem plenty of times and never found an answer so im hoping that by posting I might be able to finally get some help. All help is appreciated and thanks in advance.
geposted Wed 11 May 11 @ 5:28 pm
If you receive a constant distortion sound, try to increase the ASIO buffer size from the Control Panel of your Sound card.
geposted Wed 11 May 11 @ 10:01 pm
Skipping, stuttering and distortion is normally caused by performance issues with your computer and/or incorrect configuration in VirtualDJ.
Please see http://www.virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html for a list of common causes and their solutions.
NOTE: To use multi-channel external sound cards such as the Numark DJIO, you will need either VirtualDJ Basic or the full Professional: http://www.virtualdj.com/products/comparison.html - Home FREE has limited sound options.
geposted Thu 12 May 11 @ 2:21 pm
