I am having trouble finding a fully functional 4 deck skin for my iPhone's iRemote program from Virtual DJ.
GLITCH 1) iBlackSheep - This is my favorite skin, and is mostly fully functional, loads songs from the search results on Virtual Dj,
but.....whenever I start a song from my iPhone, it will either slow down or speed up the tempo.
I tried adjusting the settings on my Virtual Dj, no luck so far.
Anyone else have this problem, any fixes?
GLITCH 2) iPhone iMix V1.0 - This skin works good for playing the four songs that are loaded into the decks,
but it will not access any of the songs in the search results.
These are the only 4 deck skins, and both have major glitches.
I would love to be able to run the BlackSheep skin, any advice on these issues?
Also, I have been having issues with Virtual DJ pausing/freezing up for a couple seconds when I run iRemote?
This is happening at work, on a brand new computer.
Is this whole app more of a pipe dream than a reality?
geposted Sun 15 May 11 @ 12:51 am
Nice to see your still around Dan!! Black Sheep is still 1 of my all time favorites. Can't wait for iBlack Sheep.
Huey
Huey
geposted Sun 15 May 11 @ 9:52 am
iBlackSheep was designed to make it "easy". The reason the play button changes the pitch is because it has been coded to do so.
To fix:
Unzip the skin.
Open the unzipped folder and open "decks.xml" (use notepad in Windows or Text Edit in OSX)
Locate this part of the XML:
<button action="play_sync_onbeat">
<size width="75" height="56"/>
<pos x="218" y="260"/>
<selected x="+0" y="+320"/>
</button>
and change to this:
<button action="play">
</button>
Save the XML and ZIP ALL the files back together. Then reload the skin and it should now work as desired.
If you are not tech savvy then let me know and i will do it for you and send you the download link.
If you have any other ideas then let me know - iBlackSheep2 - coming soon!!
Thank you so much for the quick response!
I am gonna try this right now
To fix:
Unzip the skin.
</button>
and change to this:
</button>
geposted Wed 18 May 11 @ 10:32 pm
"djtouchdan" I tried changing the coding on the skin, but I must have done something wrong along the way.
Could you upload the skin with this coding to a link for me?
geposted Thu 19 May 11 @ 1:59 pm
