Forum: Old versions
Topic: Can't save playlists!! HELP!!
I just bought VDJ7 Pro and everything works great except I can't save any playlists. I'll name and save it but the playlist folder won't open. Any suggestions??? I've been googling for hours trying to solve it myself, it's time to ask for some help.
Thanks in advance!
~Chris~
geposted Sun 15 May 11 @ 9:36 am
Please check the permissions of the My Documents\VirtualDJ\Playlists folder and make sure that your user has permission to write to it.
Also, check the permissions on the VirtualDJ folder itself and all other sub-folders within it.
geposted Sun 15 May 11 @ 2:41 pm
That was it! Thank you!!! VDJ7 is now running flawlessly. Thanks for the fast response and the great tech support.
Chris
geposted Mon 16 May 11 @ 1:35 am
I also had the problem, but setting permissions didn't work, i made a new folder in the virtual dj folder in my documents, then i was able to save
geposted Tue 16 Jul 13 @ 6:24 pm
when i drag a song over to make a play list then go to my curser to bring up another song to drag to the play list the first 1 earases
geposted Tue 26 May 15 @ 3:31 pm
blckjckPRO InfinityMember since 2008
Are you putting songs in that have been marked played with the option to remove played songs?
geposted Tue 26 May 15 @ 10:19 pm
dont know what you mean by that is it any way we can talk on the phone
geposted Sat 30 May 15 @ 9:47 am
