Forum: VirtualDJ Skins
Topic: O.k. just read it again so I'm asking....
Boys! do you really have to take a skins files (xml & bmp) and Re-zip it after modifing something OR while in the Virtual Dj skin folfer? beats me,I've been using the files without a zip pack and they work fine...Any real reason to do this?
geposted Sat 21 May 11 @ 4:52 am
JeremKPRO InfinityModeratorMember since 2004
No you do not need to re-zip the skin files to use the Skin in VirtualDJ.
geposted Sat 21 May 11 @ 9:17 am
thats what i thought...thanks "J"...;-)
geposted Sat 21 May 11 @ 5:59 pm
This is true,I don't ZIP anything during the build. I only ZIP them for submission to the site
Chuck
geposted Sat 21 May 11 @ 11:19 pm
that makes total sense...
geposted Sat 21 May 11 @ 11:42 pm
Maybe.. it works of both forms… Single that to upload the skin it'll be .zip
geposted Sun 22 May 11 @ 11:42 am
So Tracker do you have like a hundred zip files in your folder, lol!!!
Huey
geposted Sun 22 May 11 @ 1:04 pm
Hmm...wonder then why some top skinners (dont want to mention any names lol ) say "after modidying the xml, zip files and you're good...
geposted Sun 22 May 11 @ 11:12 pm
Dozo10PRO InfinityMember since 2011
I think the zipping has to do with the download form the VDJ site ( and a little space reduction on your hard drive)
if u look at the skin Virtual dj 7 (4 decks ) its zipped about 7 mb
when i unzip i get over 100 mb thats a big differ ;) and a good reason to zip it :)
nowadays most operating systems can work inside zipfiles so why not let it , in zipped state my skins are less than 100 mb ( yes i got a lot i still am playing with them) if i should unzip them all its over 1gb!
geposted Mon 23 May 11 @ 2:35 am
