Forum: Old versions
Topic: It just stoped.
Last Saturday night I was playing a cashed video file (cupid shuffle) and VDJ just stoped dead, as well as my PC. music and video just stoped. The screen locked up and I had to restart everything. I'm not saying it was the file or VDJ or my PC. I'm asking the powers that be, what their opinion is? There was no crash report.
My Laptop:
ASUS Gamers Republic G73H Series
Windows 7
Intel Core I7 Q740 1.73 GHz 1.73 GHz
6 Gigs RAM
ATI Mobility Radeon HD 5870 Video Chip
64 Bit OS
geposted Wed 25 May 11 @ 12:36 am
cstollPRO InfinityMember since 2004
Complete hardware freeze ??? I would start with looking at an over heating issue.
geposted Wed 25 May 11 @ 7:45 am
djnutzPRO InfinityMember since 2006
I had similar issues with my touchscreen setup. The bigger problem is heat buildup problems began long before this crash. The components of the computer are most likely damaged by the excessive heat and will be more likely to have more problems like this down the road. SO while the system might seem fine in the beginning, it's like playing Russian Roulette...
geposted Wed 25 May 11 @ 10:56 am
Thank you for your input. I hope that is not the case that this is the start of more problems my laptop is brand new and handles everthing I throw at it. I had always kept an external fan on my Vaio. Should I continue to do the same with the asus?
geposted Wed 25 May 11 @ 1:26 pm
A fan can't hurt, but I would try to clean the ports. Use compressed air, and use a paper clip, to keep the fan blades from turning.
geposted Thu 26 May 11 @ 10:26 am
