Forum: Old versions
Topic: CPU usage maximum
Hey . I made format to my windows 7 . And i reinstalled VDJ. So when 1 deck playing and i add song to another deck then CPU usage is 100% and song whats playing freeze so long until song on other deck is loaded. I had before format same windows and same hardware , and i didnt had any problem with so much CPU usage that VDJ freeze . So any ideas or someone can help?
geposted Wed 01 Jun 11 @ 11:34 am
High CPU usage is normal while loading a song, especially on an older computer with single core processor.
VirtualDJ will use almost all spare CPU to load and analyse the song as quickly as possible. Unless you have serious performance or configuration problems with your computer this should not affect the live playing song.
If you find that the live playing song is affected, please check your computer for performance and/or configuration issues. A list of common causes and their solutions can be found on the following page: https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
