Hi I have my friends laptop which has a valid version of virtual dj on it, and i would like to know the best setup for two American Dj turntables with a maya44 usb soundcard. i have a numark dm2002x mixer as well.
Cheers DJ Klepht
Cheers DJ Klepht
geposted Thu 02 Jun 11 @ 1:42 am
geposted Thu 02 Jun 11 @ 2:41 am
Thank you synthet1c for trying to help but i dont seem to have access to this page.
I try putting my mates serial number of the program on here but it says serial is invalid.
Might have to save up and just buy it myself.
Regards Dj Klepht
Regards Dj Klepht
geposted Thu 02 Jun 11 @ 5:11 am
You cannot use somebody else's serial number.
Doing so is both illegal and a violation of the End User License Agreement: https://virtualdj.com/atomixproductions/disclaimer.html
Sharing serial numbers is NOT permitted. If you are using your friend's version of VirtualDJ and/or his serial number, remove it from your computer IMMEDIATELY.
Please support the software and its future development by purchasing your own legitimate license: https://virtualdj.com/products/comparison.html
geposted Thu 02 Jun 11 @ 6:09 am
Hi, I thin you misunderstand me, we are not sharing it, I know own the laptop and the program as he doesn't Dj anymore, how can I get the program transferred to me legally.
Thanks Dj Klepht
Thanks Dj Klepht
geposted Thu 02 Jun 11 @ 8:52 pm
Sorry, it cannot be transferred to you.
VirtualDJ licenses are non-transferable and cannot be sold, given or transferred to another user. Doing so is a violation of the End User License Agreement: https://virtualdj.com/atomixproductions/disclaimer.html
You will need to purchase your own license for the software: https://virtualdj.com/products/comparison.html
Your continued use of somebody else's license is illegal and a violation of the terms of the EULA:
Quote :
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix Productions.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
geposted Fri 03 Jun 11 @ 3:52 am
