I am on vdj 7 mac LE
I am now on 20 day vdj pro trial period, however i can't change any skin that come with the package I install. Not even the same skin of 4mx with other resolution.
Is there any other possible way to change the skin?
If i upgrade to pro will this still happen?
THanks
THanks
geposted Sat 11 Jun 11 @ 4:23 pm
No, most LE versions are limited about that too.
On Pro Full side you can use the hole range ;-)
geposted Sun 12 Jun 11 @ 12:37 pm
Sorry, the software that you received with your DJ Console is a free limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.)
To be able to use custom skins, effects and much, much more you will need to upgrade to the full VirtualDJ Professional. Your VirtualDJ LE entitles you to a significant discount off the cost of upgrading. To receive this, please go to http://www.virtualdj.com/buy/index.html and enter your software serial number in the box provided at the bottom of the page.
geposted Sun 12 Jun 11 @ 2:23 pm
