okay here is my setup.
vdj 7
2x pioneer cdj 400
pioneer djm 400
hp 3 gb with AMD processor ( specs are good wrote them down and got a computer with a little extra for safety so it would work for sure ) haha ya right
krk 6" monitor
now it just froze while playing and the latency sucked bad its setup in advanced config
cdj 400 asio for both 1&2 and 3&4
record loopback is set line in audio codec the only way i have found to get sound during recording
i asked on here and set it up as answered by a experienced user and had it working till just barely i was trying to adjust the sound so it does not crack and pop in my headphones while recording and it froze i cannot get the damn thing running right i have done everything i can think of and now i feel like giving up. i got this entire setup for ease and its not even close to being easy anybody have this set that could help me out. i am honestly about to say screw the software because i cant get it right but i dont like giving up. the latency was fine till now and the popping and cracking was minimal until now no changes were made until the popping got bad then i tried a few things and obviously made it worse. i just dont get why i cant get it to work now even not recording it was popping i will be very mad if nothing works and will move to something else if i cant figure it out but then ill be out all that money please help its a great program if it would work at least most of the time with no problems but damn
vdj 7
2x pioneer cdj 400
pioneer djm 400
krk 6" monitor
geposted Thu 16 Jun 11 @ 3:11 am
Have a look here:
http://www.virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
BTW:Your post is really hard to read ;-)
geposted Thu 16 Jun 11 @ 4:16 am
sorry posted from my phone but anyways i took a pretty long break went back set the settings and its working fine again the only thing is my cpu bar is higher than i would like after disabling other things i dont use. i am going to disable my webcam as well cause i was reading and seen somebody did that and it worked for him. surprised that the cracking and popping went away to maybe thats cause i disabled some things i dont know lol but thanks its just been frustrating
geposted Thu 16 Jun 11 @ 4:36 am
