Im having audio problems at ANY latency set in the NS7's settings. Program freezes for a half sec or so when this happens as well and the music stops and skips. Very random and I can't figure this problem out and have searched this whole forum and can't find any answers. Can anybody help??? I don't have this problem with my NI Audio 2 DJ card and it doesn't seem to happen at all when I try SHITCH (Itch). Drivers in the NS7 are updated for 64-bit use, and the correct 64-bit drivers are installed on the PC.
Running a Quad Core I7
4 megs of Ram
1 gig of vid memory
and this PC touches no internet or anything.
Appreciate any help!
4 megs of Ram
1 gig of vid memory
geposted Fri 17 Jun 11 @ 6:25 pm
lol I meant 4 gigs of Ram obv... Damn 4 megs would be slow....
geposted Sat 18 Jun 11 @ 11:13 am
Check out the FORUM that is titled How to get your NS7 Workin Flawlessly. It's by DJ FLUXX it's a nice forum and if you have any questions he will gladly help ya with a prompt response. If I new how to put the links in this message I would but you should be able to type Flawless in the search engine and find it
Keep Spinnin,
DJ 2Bucs
Keep Spinnin,
DJ 2Bucs
geposted Sat 18 Jun 11 @ 12:10 pm
You running 7.04 Virtual? Have you tried updating Shitch lmao to current version along with Numark drivers from their site?
geposted Sun 19 Jun 11 @ 9:07 am
Turning off Safe mode corrected 99% of my issues. I still dont like how the NS7 has pitch bend vs the Mixtrack pitch bend. Oddly the Mixtrack's pitch bend is much much more accurate... I dont get why they're different... Also when mixing two tracks and doing a loop roll out on the last track sometimes that track's audio cuts off and I cant figure out why... The new song is fine but the one being looped out's audio cuts off (waveform still continues)
geposted Tue 28 Jun 11 @ 8:37 am
I have the same issue with looping too. Thinking it has something to do with the motorized platters.
-David
-David
geposted Tue 28 Jun 11 @ 8:59 am
I am also having reports of this loop issue with the V7, but the feedback I have had is that the deck you are mixing out of jumps back to the start of the track and then starts to play again from the beginning.
geposted Sun 24 Jul 11 @ 7:59 pm
