Topic: @ blulite sorting key and bpm
sorry that doesn\'t work, but sorting by bpm then key(numeric) lists the key in order with bpm ascending, recurse your folder and you will see what I mean
geposted Sun 19 Jun 11 @ 5:50 am
sorted, thanks Synth, i would still like to see an option though rather than having to recurse then sort by key. is the recurse a must for this to work? if so why?
actually another question, how come this works when sorting by key or numeric key, yet not when sorting by Bpm?
if i sort by key or numeric key the bpms are displayed lowest to highest within that key.
so how come if i sort by Bpm does it not display lowest to highest key within the bpm?
if you catch my drift?
You don't need to recurse the folder, that was just to give you enough of the same key of tracks for you to see it work, don't know why it doesn't work the other way sorry bro, but it also works for rating/bpm, and rating/key.
odd really why it dont work the other way.
at least i know it works now though. thanks for your help :D itll be so much easier to track select on the fly now.
im noticing this isnt working on some of my folders, and when i try to recurse im getting an error :( any ideas?
